...a big bearing full width 28 spline axle? My recent purchase from Pull N Save is a ful width 9" from under an early 70's F100. I measured the bolts on the back of the backing plate and it appeared to be a big bearing rear end. Took it apart and the bearings appear to be big bearing as well, but the shafts are 28 spline. The axle shafts taper down to the splines
