Anyone else had an issue installing the drivers side muffler with the James Duff dual exhaust kit?
What I have:
- 1974 Bronco pretty much stock underneath (nothing extra or out of place)
- TBP long tube headers (not sure this makes a difference with what my problem is)
- James Duff dual exhaust kit with JD part 3093 (TBP long tube adapters)
- Flowmaster 40 mufflers
What the "problem" is:
- The length of the driver side intermediate pipe that comes with the kit lands the edge of the body of the muffler just beyond the E-brake cable bracket and cables, causing the top of the muffler to hit the cables coming out of the back of the bracket. Instructions in the kit tell you that you may need to cut length off of the intermediate pipe when using Flowmaster mufflers but that would make this situation worse since it would put the body of the muffler right at the bracket, pushing the bottom of the muffler even lower. It can all be installed and be functional, it's just that JD recommends the bottom of the muffler be above or at least flush with the bottom of the leaf spring hanger. Both scenarios - pushing the muffler down so the top doesn't hit the E-brake cables and moving the muffler towards the front of the vehicle - pushes the muffler down below the leaf spring hanger quite a bit. Rotating the muffler would raise the bottom, but JD also states that the mufflers are meant to be installed vertically without being angled.
Thanks for any JD-specific or general exhaust install help.
What I have:
