broncoman82
A little history to start with, I bought my 1973 Bronco a little over a year ago. I have wanted one since I was a kid, one of my dad’s friends had one and I remember riding in that thing on a many of fishing trips. I gave 5,800 dollars for the one I got and had planned on doing some upgrades and such to get it where I wanted it to be. This year I spent probably around 6,000 in parts to put on it. A 351 Windsor, a lift kit, body lift, power disc brakes and so on. Well the last two days a friend and I have been working on installing the lift kit and body lift. The lift kit went ok, but the body lift has been a nightmare with one thing leading into another. The body kit is a two inch kit that I purchased from one of the bronco venders. The kit came with the two inch spacers and bolts. I also went ahead and purchased a new body mount hardware kit to use. Well the body lift kit didn’t come with any nuts and the hardware kit bolts were bigger so I couldn’t use the nuts in that kit. None of the body bushings came out without having to cut/breaking them and the lift kit was designed to be used with the original body bushings, as in to be bolted into the original body hardware. The body lift kit came with generic instructions with no pictures or use full information. The shop I used was my buddy’s which is probably 20 miles from town and no way to access the internet for some useful instructions. When I placed the order for the body lift over the phone I asked about brake lines and steering shaft and was told I shouldn’t need anything. Well I found out the hard way that I will have to buy/modify those items to work, which is not a problem but to make things worse I found out that my frame in the rear is rusted really bad, to the point I worry about my rear leaf spring mounts holding up. While trying to get the body to rear axle rubber brake line off I broke the steel brake line, which now I will have to replace and to make things worse I am suppose to have the bronco at the tire shop Thursday for new tires. Today I want get to work on it due to having to work and the way it looks I will have to wait until next Wednesday before I can resume work on it. I also had it lined up for it to get new gears front and back, installed on Monday and that to will have to wait. Nothing so far is going in my favor. I work nights as a Deputy and that to makes things hard when it comes to trying to work on it. I guess I am just having a pity party I don’t know just wish things would go my way for a change on the bronco. I guess my next task will be trying to track down a decent frame I can afford now that my budget for this year has been shot.
