If that's steel, then it's most definitely not a stock fuel feed line, as those were plastic.
If that's steel and is coming off of the front two smaller ports on the tank, then they are most likely the vapor recovery and liquid return lines that feed to and from the vapor condensing tank that should be (have been?) behind the driver's seat under a panel.
They look to have been buggered around with over the years because they don't have their straight lines and clean bends that they would have had from the factory. And as far as I know, there are no replacements available. You either have to scavenge one from another Bronco between mid-'70 and '75, or make your own.
But since the steel doesn't look like it's leaking, just get some 1/4" fuel-rated hose and make your own new ends. Looks like you could reuse the old clamps no problem.
If you follow them up forward, I think you'll find that at the front of the wheel well they come together with another single one from the auxiliary tank and another one that runs off to the other side of the truck on the crossmember.
They bundle together and run up into the body panel, through an oval hole with rubber grommet, and into the condensing tank.
The one that crosses the truck to the other side goes to the charcoal canister over on the passenger side frame rail.
Looks a lot like this:
