What color did you go with for the interior?
The interior is still in epoxy primer but it will be white with white bedliner. I also have diamond plate door panels and inner quarter panels.
GnisroH - If you like shelby colors, you should like the green too it is almost identical to the old "Lime Gold" that was used on Mustangs and Shelbys.
Tito- I tried to make the pics bigger. If you can make them larger and get them to post I'll send them to you. I think my problem is that I'm using an 8 Megapixel camera and the files are huge.
Anyhow here are more pics. the front, the bumper and a couple flares sitting in the back, and two shots of the grill one is a closeup of some strange red color that came out when I shot the clear but was not there when I shot the base coat. I thing it is from some old red oxide primer that was on the grill from a very old repair. I'm going to shoot epoxy primer over that area and repaint and clear it when I paint the top. I'm thinking the epoxy primer should keep it from bleeding through again. Any of you paint experts know why this happened? I was really suprised by this I would have figured that any bleed through would have happened when I shot the color coat because its mixed 1 to1 with reducer. Also any suggestions on how to keep it from returning when I reshoot it? will the epoxy primer lock it in?
