Lets see your junkyard air boxes
mattt
I'll play devils advocate for a moment. The factory air boxes do a great job of keeping the air cool. But wow are they restrictive! They usually have a very small inlet.
Is a lot of warm air better than a limited amount of cool air? The massive air leaks into and out of our engine compartments is pretty high. Next time I'm logging data I am going to see what my AIT is with my boring open element K&N hanging off the throttle body.
Ding, ding, ding...winner! That is why I went with a factory air box that could be modified to allow more air coming in. There is nothing "Cold Air Intake" about any of the open type K&N filter in the engine compartment setups. They're sucking up that hot air under the hood.
Spend some time looking at different factory box setups and there are a few out there that can be modified to flow adequate air for any realistic Bronco power plant. The advantage to a factory air box is some/most have mounting provisions for the MAF and calm/quiet the air down as it enters the intake tract, vs. having to build a shield to keep fan wash away. YMMV....
ntsqd
heratic car camper
Upper SoKA
Search the "Deck-plate mod" to see how late model Tacoma drivers deal with the supposed excessive restriction of those air filter boxes.
Bronco_69
Monette Ar
my airbox is not restrictive and gets cold air. mustang owners used to ditch them them for the "open" element but quickly realized that the hot air and fan wash hurt performance. i have ran 9 second 1/4 miles with a stock airbox and k&n filter.
markw
Hey ntsqd check out the NORRA thread, I posted pics of the Ford airbox you were looking at. Mark
toddz69
its really odd shapped so a measurement is not going to help. is there a particualr fit question that i can help you with?
No worries - I checked closer and know it won't fit my configuration. Thanks for your offer.
Todd Z.
hammer
hammer
bump. anything new? Had to start running higher octane fuel as I really noticed a lack of power at higher rpms in the heat this summer. Need to get this delt with before next summer. Problem is, I'm really running out of room under the hood. I'd like to utilize the plastic heater box inlet if possible. Seen it done but it was super custom/lots of work. Gotta be simpler way to do it.
ntsqd
heratic car camper
Upper SoKA
It was detonating because of the hot air?
Sounds like you're going to have to move something to make some room. Lots of options have been presented. It's either that or pick a filter element and build a box to enclose it that fits somewhere.
Are you sure you are not running out of fuel? Clogged filter, weak pump?
73azbronco
pulled one off a volvo turbo of all things and an f250 superduty. Still tinkering... But in mean time, cannot get over how easy the stock offset aircleaner is. Some back of the napkin math shows you need about 1 ft square of filter element to support the horsepower. IAW I picked vehicles which had at least 5.7 liters of displacement.
Steve83
1) High-octane fuel has LESS energy, and is HARDER to burn than cheap stuff. So it will only contribute to a lack of power - it won't remedy that.
2) You're in Canadia - your summer "heat" doesn't compare to Arizona & Florida, where the stock air cleaners work. If you hear detonation, you can be sure it's NOT because of the air filter box. Look at the things bowsher mentioned, to start with. %)
hammer
hammer
Well, it fixed it.
Anyways, this thread is about air boxes. Not my detonation issues.
Carry on.
Edit - stock air cleaners pull air from outside the engine compartment. Which is why they work in Florida and Arizona.
ntsqd
heratic car camper
Upper SoKA
Back the timing off a couple degrees and you can probably go back to the cheep stuff.
ntsqd
heratic car camper
Upper SoKA
Why? Because after 3 pages of suggestions none of them is a perfect fit, yet you don't seem inclined at all to try any of the options to see if they might work with some mods? Modifying Broncos is a big, scary thing and not for everyone.
hammer
hammer
Wow.
Cause the thread is about air boxes. Not my fixed detonation issue. How many times do I need to lay it out.
ntsqd
heratic car camper
Upper SoKA
How many air box suggestions do you need before you'll actually try something? The sense I'm getting is that you want the perfect solution spoon-fed to you.
hammer
hammer
This thread is 58 posts long. It has 5 suggestions. 1 is not ford efi. 1 is still pulling air from inside the engine compartment. So 58 posts and 3 suggestions, all of which involve relocating the battery or flipping the intake to the passenger side. So yes, i'm still looking at options.
Feel free to move along if you don't have anything to ad.
ntsqd
heratic car camper
Upper SoKA
Nah, I'll continue to spectate and comment when I feel like it. Thanks anyway.
FWIW A complete list of constraints along with illustrative pics in the first post would help a lot. As opposed to shooting down suggestions one at a time because they don't meet previously undisclosed constraints, which leads to where you are.
