Finally got the 74 tagged and insured so I could really drive it more than jist around the block. Feels good to have it back. Nothing blew up or leaked. She does run a bit hot, but I expected that since it is a .030 overbore. (190 on the freeway 210 in traffic). Cooling I can handle, but I've got a few issues I need guidance with:
Problem #1
Newly rebuilt C4. (I trust this guy since he has done 6 trannys for me in the past). Problem is he's 250 miles away. Hoping I can just adjust i myself. Soooo, it doesn't want to shift all the way back into first when you come to a stop. Manual shift down and then back to drive and it is fine. Shifts hard into second then kinda slides into high. Shift points are about 8-10 mph, 18-20 mph and about 28-30. What would cause this?
Problem #2
The power band is flat. Nothing from 800rpm up to around 1500rpm. Idles fine, in and out of gear. Holds 800rpm dead steady in gear. hold it first and run up to 2800 shift to second and run up to 3500 - 4000 and it starts stumbling and skipping. Timing???? I installed a comp cams RV cam along with all new internals. Balanced lower end. It revs well with no load but is a dog in gear.
any ideas would be greatly appreciated.
Problem #1
Problem #2
