...Your right I have the large gauge cable with the bus fuse that you guys sell and will use it to go direct to the battery, unless you recommend it going to the Starter relay.
No recommendation either way here. It's basically the same thing, just separated by a few inches of battery cable. Same function, so you use whichever is more convenient at the time.
I've ended up connecting it directly to the battery lug bolt just because some of the starter relays have had so many wires on their posts that it's just getting kind of crowded there.
Currently the wire from the Stator side of the voltage regulator goes to the choke (I have an Edlebrock carb with choke, and unfortunately I no longer live in Montery, I am on the East Coast where it gets cold).
That's not doing anything any good, as it's not the stator connector of the regulator that powers the choke. It's the stator stud on the back of the alternator.
And it's not correct for an Edelbrock choke anyway. That one needs 12v instead of the lower voltage coming from a stater output.
So find a good 12v source, on with the key in RUN only, under the hood.
There are a couple of extra switched sources under the hood with a Centech harness. A 2-wire connector with Green wires going to it is one. Not sure if it's on only in RUN, or if it's on while the key is in ACC position too, but that's easy to check with a volt-meter.
My question is doesn't it require a wire from the alternators stator wire to the regulator? If so, how do you do that?
No.
Early Broncos never came with the stator wire connected to the regulator. There are generally two wiring schemes that Ford used with the regulator. One for vehicles with an indicator light on the dash, and a different one for vehicles with an ammeter. Like all EB's had.
Your regulator should be wired this way only:
1. First position is the "F" terminal and has the Orange wire to the FLD post on the alternator.
2. Second position is the "S" terminal and gets the Green wire from the Centech harness marked "REG S" and has 12v only with the key in RUN.
3. Third position is the "A" terminal and gets the Yellow (I think?) wire from the Centech harness. Stock is Yellow, but I forget what color the Centech is for some reason. It should be marked either "REG +" or something similar and has 12v all the time.
4. There is no 4th wire on a Bronco. The "I" position of the regulator is left blank.
I don't have a Centech alternator connector in front of me, but if they have the other wiring scheme, you would simply remove the contacts and wires from the main connector and relocate them to different positions that better match what I wrote above.
It's an issue with replacement connectors sometimes. The store-bought stuff might be wired for the more common light-equipped cars, while a few are wired for the ammeter equipped trucks like ours.
The other issue I have is that on my 351W I was using a different kind of alternator mount and the case is so huge on the Mean Green Alternator that it hits the mount attached to the head and limits any adjustment. I think I need to buy the mount like you guys sell as it goes across the top front of the head instead of the bottom front like I have. I also need a spacer for the alternator.
I would have thought you'd have a spacer even with the 3G. Was that not the case? Do you have a pic of your existing brackets? Did they come with the 351, or were they swapped in from another engine?
You might be able to get away with just our adapter for the 351, but that would be only for use with stock original Bronco brackets.
In the case of our brackets, they should work just fine, but you might have to elongate the adjuster slot slightly for a better fit.
I did, but I know of members here who had to make no modifications to make theirs work.
Pics would still be good though. You might be ok, or you might need all of the above. The brackets, the spacer, and the adapter.
