adam05ford
Anyone know much about mechanical advance on a distributor and how to go about what I would need to get it close? I just got a new distributor and it had this chart on the box but I'm not sure which would be best.
It's called Minimum Best Timing (MBT) or basically the point of diminished returns. Where adding more timing stops producing noteworthy performance gains and only results in diminished knock threshold.I remember doing some dyno tuning. The rule for timing is run as little as possible without loosing power. With more timing power goes up. There is usually a platau where the power levels off. Then more timing will hurt power. The low end of the platau is generally the best target. Detonation can limit it even lower.
Basically run as much advance as you can until the engine pings. As has been said a lower initial advance helps I like to run 10-12 initial the rest is mechanical. I really dont factor in vacuum advance but if yours is adjustable and you get pinging try backing off the vacuum advance first before backing down the initial or mechanical.
