Salashhavoc
Not a mechanic
- May 12, 2012
- 68
City:
Hattiesburg
Price: $ 1
Price: $ 1
Champion Radiator - Used. trans cooler leaks from bottom inlet, otherwise, worked great. Used for 7ish years
C-4 Cross Member
Ford 9in Center Chunk - Upgraded and no longer need. Maybe 4.10s?
28 spline axles
3 Steel Fuel Tanks - One is a few years old from TBP. 2 others are saddle tanks one is 12ish gallons, the other is just under 9. All great tanks, no issues
Saddle tanks have two mounting options if interested
1 Fuel tank protective plate
2 Visors
Ebrake cable set
Hood prop
Bump stops
Shift handle for D20
Viaair - 1 Gallon Tank
Fuel tank filler and vent hose
Upgraded Alternator -, purchased from TBP 7 ish years ago
misc u joint and u joint straps
Fitech fuel pump and filter - Used.
$650 takes it. I travel into LA, GA, & SC occasionally and willing to meet up depending on time and location.
Thank you,
-Tim
