MT Classic III, will I need wheel spacers?
ScottyP
I have a 2.5 inch suspension and one inch body lifts and I’d like to run 33x12.5x15 tires on 10 inch wide wheels. I currently have wheel spacers and I’d really like to eliminate them. Will the MTs work without and if someone could tell me which backspacing that would be awesome.
SHX669
What year is your Bronco? '76 and '77 don't have as much Clearence for the TREs.
No reason I can think of that you would naturally need spacers on a '71 with 10" wheels.
Unless there is a disc brake conversion installed that created a clearance issue. Especially true if it's a Ford swap to '76/'77 Bronco knuckles/brakes.
How is yours set up? What was on there before and how thick are the spacers?
And presumably your wheel well openings are cut and flared?
sprdv1
REBEL
you should sign up for pics...
S
ScottyP
My fenders are cut. Has slot mags, 31 inch tires and 1 inch spacers that were on it when I bought it.
Dlesage23
Newbie
I’ve got a 74 with the exact setup your describing, including the same wheels and tires. Check the pics in my garage, but I had no problem at all. Part No M/T90000001762
S
ScottyP
Perfect. That’s exactly what I was looking for. Thanks
S
ScottyP
Well, turns out it can’t be that simple and my 71 truck has tie rods from a 76. Can I get away with 15 inch wheels with 3.625 backspacing? Options with 3.5 or les BS seem to be very limited.
S
ScottyP
From what I’m reading I think I’m stuck with spacers. I hope there’s some advantage to the 76 components since it adds to hassle with wheels. Next question, if I use a wheel like the MT with 3.625 backspace, getting me pretty close, any reason I can’t go from a bolt on spacer to a more minimal sandwich style spacer?
S
ScottyP
What’s my beef with spacers? I had the rear wheel off this new to me truck checking out the non-functioning parking brake and discovered these spacers. I apparently didn’t torque everything adequately after and had the wheel nearly come off on the road damaging several wheel studs. Attempting to fix that (on the road and back in my garage) I find that I can barely get a socket into the spacer to the lug nuts and I’m having trouble finding lug nuts thin enough to fit down into the spacer. I’ve never used spacers before and I’d sure be more confident with my wheels snugly next to the hubs.
