BamaBronco73
??? First of all, I have a 73 w/ 302, stock(?) Motorcraft carb, stock points-style distributor.
I have noticed my Bronco running a little rough at idle lately. Seems to have been doing it about 50% of the time. Yesterday while driving, it just died at a red light when it dropped to idle from driving speed. I pressed the accelerator and it would crank back up. As long as I pressed the gas it would run (though a little rough) but would die when it went back to idle. Returning home, I could keep it running when I pushed the gas, but if I had to coast or come to a stop, I would have to shift it into neutral and rev it up. It cranks fine if the gas is depressed, but will not idle.
Any help is greatly appreciated. I believe it has to be either the carb or the distributor.... just not sure which way to lean to. May be leaning a little to the carb, as it just seems not to be getting gas at idle. It has new plug wires, plugs, fuel pump, fuel filter....so I can rule those out as they have been operating well for the last couple of months.
Thanks in advance.
Thanks in advance.
