70twocan
1977 Bronco with a 1977 302 that has serious blow by. I did a compression test and the #2 cylinder is ZERO. I preform a wet test (add oil to the spark plug hole) and the compression jumps up to 110lbs.
The PO let it sit for a couple years then pulled the Bronco out of a barn and said that's when the blow by started.
I put some off the shelf cleaning solution on top of the pistons and will let it sit overnight.
I'm thinking I have bad piston rings on the #2 piston. Before I tear it down, I thought I would ask if anyone has had this problem before and if so what was the fix? (replace piston rings?)
