Oil pan dipstick leak modification
DeepC73
Hello,
Like many of you, my 73 Bronco has been leaking oil everywhere from around the dipstick. I scoured the forums looking for ideas and solutions. Originally I was going to take it apart and try a different solution. However, after disassembly I came up with another idea. I used a 7/16 tap and dye to thread the original push in tube on the oil pan. The 7/16 fits the outer sleeve of the original dipstick tube perfectly. After replacing the gasket and replacing the rivets with bolts I came up with this configuration. I am reassembling tomorrow. I will keep you all posted.
https://share.icloud.com/photos/0v9deHbaGkMM_WLzk27nV4ITg
56f100bbw
Tucson / lakeside AZ
No leak
I modified mine and it works great no leaks drill and tap cast iron made new gasket and thread sealant on bolts
DeepC73
DeepC73
Did you use rev on the gasket? Did you gasket both sides? Just wondering. I ended up putting a gasket on both sides. I think it was overkill, but really tired of it leaking.
DeepC73
DeepC73
Well, I didn’t think this through completely. Due to the curve in the dipstick tube, it won’t screw in once in place because it hits the fender well. DAMNIT! Lol
