69_Sport
- Nov 5, 2014
- 261
The viscosity needed for adequate oil pressure is not mentioned in any of the above comments, yet that is likely the most important consideration.
One should run the thinnest oil possible that gives adequate oil pressure once warmed up.
One size does not fit all. Each engine is different, with internal clearances and wear determining the pressure.
If you are worried about which oil viscosity to use, yet you don't have an oil pressure gauge, you are already in over your head.
