bobscott
- Mar 18, 2013
- 310
So I took off early from work yesterday to break my motor in. Hopeing to take my daughter for a ride when she got home from school. Not sure what happened but being dumb I overheated it and I think killed it. It was filled with coolant, fan and shroud were on. I even had a barrel fan set in front of the truck cranked on high. It started right up, I took it to 2000 rmp and it was holding a bit high 220 degree or so. I took my eye off the temp gauge for a few minutes to watch the tack and the motor sounded like a cylinder stopped. I looked at the temp gauge and it was pegged. I let it completely cool and it restarted but hard and wouldn't stay running. it also wouldn't build much oil pressure. Today I pulled the distributor and the oil smelled burnt bad. It was hot as the headers were glowing. the motor does turn over but it won't start.
All this said after a 12 pack last night I have resigned myself to the fact I screwed something up and will need a rebuild or new motor. What to do. I am going to find a shop to swap this motor out and would like some input. Should I go with a roller? I have the bc serp kit on the front and an nv3550. I also have an affordable kit on it. Would going to a roller make any of these not fit? any other recommendations?
