project tetanus build thread.
NewDog
Surrey BC
I made another small change today. I have always liked a wood steering wheel. and I really like the one in my bronco. It is from wild horses, and I like the way it looked and felt. The only problem was it didn't match anything else in the bronco. I also never really liked my center console. it is a popular design and I see them in a lot of broncos, but I never really cared for the way it looked and I never really liked the cup holders. they sat too low and sometimes my bottles would fall out of them on sharp corners. anyway I found this new console on facebook. it is a custom mahogany console that matches my steering wheel. it also has a black top that matches my seats and dash pad, and the aluminum badges and trim tie into the rest of my bronco, so I think it looks good in there. since it was so nice today I took the bronco to play pickle ball and took some nice sunset pictures on the way home.
View attachment 931136 View attachment 931137 View attachment 931138 View attachment 931139 View attachment 931140 View attachment 931141 View attachment 931142 View attachment 931143 View attachment 931144 View attachment 931145 View attachment 931146
It's a real beauty. That second pic especially is calendar-worthy IMHO!
mustanggarage
mustanggarage
I drove the Bronco over to Des Moines a couple weeks ago for a cruise in with some members of the Iowa Bronco club on facebook. pretty much all Gen 6 owners so I wanted to take the 71 because some of them have never seen a first gen bronco up close. anyway I found out after that cruise that I have gotten spoiled lol. I have gotten used to my cruise control and I really missed it in the old truck. so I started thinking about it and decided that I could always try to add cruise. of course since my truck has all kinds of modifications I had to figure out a way to make it work. some of the things i had to work around are, I have an aftermarket Ididit steering column polished aluminum. I have a dual quad sniper system, I have a push button keyless ignition system, and I have a gps speedometer. so I started looking into options. dakota digital has an add on electronic cruise control. it has a few options for how to make it work. I found out they have a seperate module called a BIM module that allows you to set up a stand alone gps cruise system. they also have a polished aluminum handle for the controller. so I bought the system and started installing it. I have it in and it seems to be working so far. I will have to do some more testing but so far so good.
this is the cruise control system I used. https://www.dakotadigital.com/index...uct_id=48/category_id=477/mode=prod/prd48.htm
this is the expansion module that allows me to have a complete stand alone gps signal that does not tie into my speedometer at all. https://www.dakotadigital.com/index...t_id=837/category_id=646/mode=prod/prd837.htm
I could send the signal from the bim module to my speedometer, but I don't really see the need at this point. the bim module has a digital readout that shows the speed, but as long as it is able to hold a steady speed where I set it, it really doesn't matter if the two agree exactly.
I wanted to mount the cruise module under the dash where the old fresh air vent used to go, but dakota digital doesn't recommend mounting them inside the cabin, so I mounted it on the fender. I didn't like any of the options for attaching the cable to the throttle linkage I had so I bought an aftermarket bracket from speedway and that seems to work so far. I mounted the bim module in the glove compartment, and I didn't want to mount the antenna where it could be seen and they said you can mount it under fiberglass so I mounted it in the fresh air duct on the passenger side. since the vent really doesn't do anything anymore it is hidden and seems to work fine so far.
mustanggarage
mustanggarage
I had to replace the ac compressor due to a dumb mistake I made, so I decided to do some other minor things to "neaten up" the engine compartment. I ran the ac line out through the drivers side fender so it does not loop near the steering column or header, i replaced the power steering pump pulley with a black billet piece that is not painted, i replaced the upper radiator hose with a silicon version, and put new hose clamps on it, i replaced the alternator with a chrome version, and I re plumbed the fuel lines so they look nicer to me. nothing major, but I think the overall effect is positive.
Speedrdr
OLD night owl
Paris, MS
View attachment 938334 View attachment 938336 View attachment 938337 View attachment 938338 View attachment 938339 View attachment 938340
Love the look of your half cab! That’s what I want mine to be when it grows up.
Randy
mustanggarage
mustanggarage
Randy
thanks. it is in the works. I am waiting for my paint guy to get an opening. ultimately I plan to have it painted Brittany blue to match the rest of the truck. I have considered painting it silver to match the stripes, because I kind of like the way it sits now in just the gel coat.
