Quadrajet ?
I do not know what Chuck uses but get on from a 350 chebby V-8. After rebuilding you will probably have to adjust the secondary air valve about 1/8 th of a turn to open quicker due to your 302's air consumption. I know Chuck has special modifications done on his carbs that may make it better in the extreme conditions but after doing 3 of these I have never needed them. Unless you have access to these carbs cheap and put in a quality kit his prices are not out of line.
jonylost
Dallas, Tx
Pretty much a Q-jet is a Q-jet shell wise. If you ask for a 1970 cheby 1/2 ton PU with a 350 4bbl and your local parts pusher........you will get a q-jet. Chuck did some internal parts mods. Stiffer secondary springs and stuff like that. Great carb for crawling!!!!!!
Jeepster
[quote author=canadabronco link=board=5;threadid=9857;start=0#71258 date=1033824436]
Here's a silly question that may make me look stupid but.... here goes.
Who makes them? I see that people call some holley's q-jet's. As well as Edelbrock?? Then I see Rochester. I'm confused. :p
[/quote]
Rochester - AC Delco plant NY
