Been messing with my overall brake system to get things tuned up and was digging into the rear brakes that PO had installed (BC Broncos Cadillac rear brake kit).
I noticed when I took off the caliper that the clip as shown in caliper pic below wasn't seated in the "groove" on the piston and instead was only hooked on the pad and the clocking nub on the back of the pad (the clocking nub I'm referring is shown in last pic circled in red). Installed like this, I can't really tell if the clip is getting between the piston surface and pad backing plate, but the rear brakes haven't worked like I want, so working to eliminate all possibilities, even if not likely to be causing an issue.
Question 1: Do I have that correct that the clip goes around the groove in the piston and also hooks over the edge of the pad? (pic below from Caddy manual seems to show that and installed that way would preclude the clip from getting between the piston and pad backing plate)
Question 2: I think the only regret of not installing the clip is the pads might rattle. Opinions?
Not looking for responses of "why not install the clip"! I might very well do that, mainly trying to understand how the OEM designed the system, and maybe help the next Bronco owner behind me.
