taz7nads
i have finished renewing all of the brake system, and am now to installing the new master cylinder. i bench bled as per the instruction, but noticed that the plunger/piston in the unit does not come back out as far as it did when empty. initially, it was at the outermost position, and I pushed it with the push rod to bleed it. now, it is farther up in the unit, and does not come all the way back out, and the push rod has to go up into the hole to make contact. is this correct?
