CopperBronco
- Aug 13, 2021
- 375
I’m installing a crossover tube for my lower radiator hose. Bought Wildhorses 5.0 tube… it did not come with rubber end connectors to attach on each side. Cutting my own.
I’m having clearance issues. Either it wants to touch my PS belt, or hit the crossmember of the frame. I bought some hoses with some different shapes / ends and have been cutting to size trying to get perfect, but just not quite there. A couple of questions:
How much clearance do I need between belts and hose?
Can I use a flexi-hose for a crossover tube? Or does anyone know of any cuttable flexi hose I could attach to metal crossover tube?
Can I just wrap hose with some rubber to protect against it vibrating against crossmember?
Has anyone used Gates power grip thermal couplers? You hear shrink the coupler onto the hose connection, curious if you’ve had luck as my hose connection doesn’t line up perfectly flush.
Lastly any parts recommended for a crossover tube for a 302 and a 4 core radiator? Mine is from TBP.
See photos of the fit mocked up here.
