Radiator hoses for a 5.0 and reverse flow radiator
blubuckaroo
Grease Monkey
Ridgefield WA
I'm using a Bronco "reverse flow" radiator on my '62 Ranchero project. I figured, it's a good fit for the Ranchero and the weld ins & brackets are available.
So, now I need the hoses. I see that WH has them, but my concern is that I've mounted my radiator centered on the core support. This radiator in a Bronco is mounted to the passenger side by almost three inches to make room for the steering box.
I talked to Toms, and they recommend '87-'93 mustang hoses.
I see that this has been covered here before, but I'd like to know how these hoses worked out for others. Were they long enough? Did you need to trim them?
56f100bbw
Tucson / lakeside AZ
This worked for me Champion radiator reverse flow
Green_Bastard
These are the hoses I used. No trimming needed.
upper hose Gates 21159
lower hose Gates 20841
