9 inch rear with 3.50 gears limited slip
just had it rebuilt year and a half ago. starting to make some noise again. could it be bad bearing or a bad rebuild???
HELP
Jack it up and try to wobble the wheel up and down. Its the easiest to start and see whats going on. After that, you can check the driveshaft for slop as well.
i have added limited slip additive. still makes noise around 30 mph but stops as i apply the breaks.quietn down when i slow down maybe something in my hub.
Sounds more like a bad axle bearing noise. Could be driveshaft too. Noises are hard to pin down from the driver's seat. Have you looked at your u-joints lately. Do wobble test as Evil69 says.
