raleigh_bronco said:
Is the alignment tool generic or is it just shaft diameter dependent? What is the size I need?
thanks to everyone that replied to this thread... I feel a bit more confident now, which is scary.
The tools are available either way. For your application I would just recomend an application specific tool. Don't worry, they often come in the clutch kit. If not they should only be a couple of bucks.
The one size fits all tool has expanding arbors and is much more expensive.
I have had luck using screwdriver handles and have known other people to just remove the input shaft from the transmission to use as an alignment tool.
As for the piolet bushing, I used a large bolt. Put a few wrapps of eletrical tape on it to make it a good fit into the old bushing. Packed with grease, put in bolt, hit with hammer, removed bolt, couple more shots of grease, bolt again. Took about 5 reloads of grease to "jack" the bushing out of the crank.
