Ol Buc
Carburetor: Rochester Quadrajet 4 bbl, 750 cfm, Spread Bore, Electric Choke, electric A/C RPM bump module, Single Fuel Inlet. FORD, CHEVY, GMC, BUICK, OLDSMOBILE, marine, carb. worked perfectly when removed from vehicle, fuel injection like throttle response.
Benefits Of A Quadrajet:
Economy: Since the Quadrajet has different-sized primary and secondary venturi, the small primaries make the carburetor more efficient than even a large two-barrel, or square-bore four-barrel. The smaller primaries act as a small two-barrel carburetor until the accelerator is pressed far enough to open the secondaries.
Drivability: The small primaries deliver great throttle response at part-throttle application.
Off Road: The Quadrajet’s centrally-located float is highly resistant to fuel slosh caused by cornering, hill climbing, or acceleration. ,
Carburetor Adaptor – Square Bore to Spread Bore, aluminum, .750 inch thick, carb adapter plates allow you to bolt a different bolt pattern carburetor to your existing intake manifold. Example: mount a Rochester Quadrajet 4 barrel carb. on an intake manifold designed for square bore carburetors, gaskets included. $15.00
