Well guys I am stuck. Im in the process of converting a new 408 to efi in my early bronco, so why not convert to serpentine set up, and while Im at add a saginaw style steering pump, and possibly adding hydro booster as well, but first I have to get past this. So after reading a bunch of threads on converting to saginaw style pump I was told i could use the same bracket as a 302. So the 302 and 351 brackets for the serpentine set up with saginaw style pump are the same, well, not so fast. After being told they are the same I had purchased one, $65 pump, bracket, and hoses shipped to my door. After trial fitting, the bottom of the pump bracket hits the top of the steering box and I only had one bolt in, the one closest to the center of the engine, any one else run in to this problem??? This bracket and pump was out of a '92 van.
