GrillMaster
- Jun 5, 2008
- 2,484
About to build some on mine and I am looking for ideas!
Here's one that I made for the trans. The last photo is of one that I am currently working on for the transfer case. I haven't had any problems running just the trans mount but I am nervous of the weight of the 205 hanging off that tail housing.
The trans cross member utilizes the factory mount you'd find for a ZF or M5R2. I have the Mazda but I believe they mount the same. I plan on running just the transfer case mount if it all works as planned.
I'll post up some pictures when I complete the transfer case mount.
Where did you get the poly bushings, what size are they, and what size tubing did you use for the transfercase mount?
I used the BC Bronco ZF crossmember but modified it to clear my upper link bracket on the passenger side. Then I used a clocking ring to get the np205 front driveshaft out of the way of the crossmember by clocking up the t-case. I also drilled the frame to use the factory np205 mount but modified it to use a poly trans bushing I had laying around.
