Here's my 73. All glass except the windshield. Kentrol tub, and everything else was picked up second hand over the years and are all different makes. In case you're wondering, the guy who laid up the tailgate used plain steel tubing, it had already started to rust and split the bottom so I cut it out and put stainless in. Also put a plate on the bottom back corner of the doors that I attached a turnbuckle and cable to the upper hinge bolt on the inside to take some of the stress off of the front of the door at the hinges. Glass is a lot of work but I looks as good as the amount of effort you put in and won't rust out up here in Ohio.
