lowbush
I am looking at a fiberglass tub made several years ago, and the inside panel near the rear fender wheels is "glassed in" solid and you cannot access the bedside area where you bolt the top's sides onto.
It is glassed on the inside of the bed, and the area above the filler neck region. And of course, the fender is on the upper outside edge.
So, you can't reach under as you would on the stock tubs to hold the nuts onto the bolts.
I am wondering if anyone who has a fiberglass tub like this could tell me how you fixed the top's mounting system at the Bronco's bedside?
I just want to know how this is mounted before I purchase the tub.
Thanks,
Charles
my tub does not have the inside panel it's the old Kentrol, but what I plan to do is add plates with nuts in them and then glass that in under the rail, on one that has the internal panels all you would have to do is cut access, then add the plates and then take the pieces of glass that you cut out, put them back with some epoxy and then add a light finish cloth over them. The nice part about glass is it is easy to work with and very forgiving.
