Cafireman07
- Joined
- Jul 8, 2021
- Messages
- 3
Am I being too simple minded, or is this a good idea? I am upgrading 71 bronco with a Holley Sniper EFI and I would like to maintain use of my auxiliary fuel tank.
Is it possible to attach an open direct fuel line from your auxiliary fuel tank with the main tank and have them function effectively as one tank? Given that the main tank sits lower than the auxiliary tank, but the gas fill spouts are at the same level.
These are my thoughts:
1. Given that the tanks are connected, when you fill the tanks, the fuel level will passively fill to an equal level in the fuel fill spouts. It may take a minute or two, but it should equal out.
2. When you drive your bronco, fuel will be taken from the main tank to the engine. The fuel from the auxiliary tank will passively gravity flow to the main tank until the auxiliary tank is empty.
3. When the auxiliary tank is empty, you would then operate with the remaining fuel in the main tank.
I understand that many people like to provide a fuel line with a fuel pump and pump fuel from the auxiliary to main tank. I am wondering if this is necessary.
I have a 71 bronco with a 4 speed manual top loader. I plan to put in a Holley Sniper EFI with the no fuel return feature.
I have asked some of the efi experts at some of the early bronco venders, and at Holley. The early bronco guys seemed kind of stumped because it was so simple, but were unaware of anybody trying it. The Holley guy was not familiar with early bronco two tank system.
I’m throwing this out there and hope to find some additional input.
Thanks.
Thanks.
