Need some advice. I am rewiring my Bronco using new wiring and I am down to confirming power from the key to the starter. Here is what I have:
I am trying to confirm I have power running through the starting system without cranking the engine yet. So far, I have:
- “Kwick Wire” loom
- Mini Starter
- 3g Alternator
- Stock starter solenoid
- 12 volts from the battery to the “S” side lug
- 12 volts from the coil to the “S” post on the solenoid when key is turned
- 12 volts from the “S” side battery lug to the starter
- 0 volts from “I” side lug to the mini starter post when the key is turned
