Are oil pan pickups proprietary to the shape of the pan? Where can I find an oil pickup for a stock early bronco? Struck out at the regular parts houses. Thanks.
I have both the Ford Fox/Panther body and original EB pickups. They look almost identical. The later pickup is at the machine shop so I can't compare side by side right now.
If your changing pickups, do yourself a solid and get some modeling clay, install pickup then push oil pan into place with clay wrapped in plastic wrap under pickup, clay should mush down to say 1/4 inch of thickness. You dont want to much space, nor to little.
Today I compared the OE pickup to the Fox/Panther pickup. The screen on the OE Bronco was about 1.5" lower than the late duel sump pickup. So the OE Bronco pickup won't fit in a Fox/ Panther pan and the Fox/Panther pickup may suck air when used in an OE Bronco pan that has a deeper sump.
Ford Racing 351W oil Pan: Steel ... rear sump (7 quart) pan with louvered windage tray and crankshaft scraper - 9 quart capacity -M-6675-FT351 front sump .
They make both rear and front sump. Just an option... $$$
The OE 289/302 oil pan for EBs is the ONLY pan made for the EB chassis. Anything else will be hit by the front axle/differential at full compression. I know now the pickup is also unique. The Ford Racing pans are made for Fox/Panther body cars not EBs. Tom's does have original oil pans so they may have the corresponding pickup.
I am swapping an original EB pan onto a 5.0 out of a Fox. It was originally mocked up in a truck that had a 5.5" suspension lift, and I guess the builder did not think there would be any interference. I swapped the motor into a stock suspension restoration, and it is very obvious there will be a problem with the Fox pan with stock suspension. Hence the need to swap back to a factory stock pan
Got the listed Melling pickup on order, and will be available for pickup tomorrow
