Transmission cooler from '99-newer 7.3L Super Duty. This is a stacked plate transmission cooler, with the additional feature of fins (like a radiator) between the plates for additional cooling surface area. It measures approximately 23" wide x 5" tall. I ran it for many years in my own Bronco behind the front bumper and then later behind the grill. One corner (right hand side visible in the photo) was "massaged" slightly for clearance under the driver's side market light. It is cosmetic only - the cooler does not leak.
In 1999, Ford ran this as the ONLY transmission cooler on the F250/F350 Super Duties (they did not go through the radiator).
This cooler is made by Long, who makes many coolers for the OEMs and also for the aftermarket (B&M etc.). It has been cleaned and flushed and has AN -6 adapter fittings in each port for the option of running -6 fittings and hoses to it. I trimmed the original bracketry for my own mounting configuration in my truck. The cooler has two mounting tabs as shown with 2 holes each for a variety of mounting configurations.
$30 includes shipping to your doorstep in the continental U.S.
Thanks,
Todd Z.
Thanks,
Todd Z.
