TBP's Exclusive 3-Core Aluminum Radiator
tomsoffroad76
TOMS OFFROAD
For those who haven't seen it already, we now have a new 3-core Aluminum Radiator for your early Broncos. This radiator was designed by us and is made exclusively for Tom's Bronco Parts. A duplicate of the original stock radiator with the exception that this radiator is Aluminum which dissipates heat better and has a high-efficiency core (48 fins/sq inch). Another great feature is that this radiator will mount into the factory brackets. You can check it out at the link below:
TBP Exclusive 3-core Aluminum Early Bronco Radiator - $299
tomsoffroad76
tomsoffroad76
TOMS OFFROAD
We don't offer a reverse outlet version of this yet. Not sure how far down the road that is, but I know it's been discussed.
As for the comparison of these radiators to a Champion, there's no comparison. The craftsmanship and fitment of these new 3-core aluminum's is top-notch. These radiators also have stamped, ribbed tanks that not only look better but also reduce potential leakage areas by eliminating the fabrication welds. Also, remember that ours fit the stock brackets, so if you don't want to buy new ones for dress up then you can save $45 right there.
Thanks for the replies from both of you. Have a great week.
-Garrett
