Topsy turvy
Howard2x4x4
topsy-turvy
tŏp″sē-tûr′vē
adverb​
  1. With the top downward and the bottom up; upside-down.
  2. In or into a state of utter disorder or confusion.
adjective​
  1. Turned or positioned upside down; inverted.
  2. Confused or disordered.
noun​
  1. The quality or condition of being topsy-turvy.
  2. A topsyturvy condition; great disorder; confusion; chaos
Howard2x4x4
Howard2x4x4
Yeah, I guess that'll work, at least the parts about disorder, confusion and chaos. I've taken a bit of a break from truly trying to accomplish anything meaningful on the Bronco for the time being and decided to putz with a top, or two, or in my case, three. I've got a Rampage cinnamin spice soft top, a normal (for now) hard top, and a hard top in the process of being abreviated to a safari top. Here's a post from a few days ago that may get you into the spirit. https://classicbroncos.com/forums/threads/what-have-you-done-to-your-bronco-today.146837/page-1301 post 26,020 Here's a post of the soft top, https://classicbroncos.com/forums/threads/buck-n-a-bronco.286019/page-23 post 451 And here's a post that goes off the tracks a bit. https://classicbroncos.com/forums/threads/buck-n-a-bronco.286019/page-24 post 466
Howard2x4x4
Howard2x4x4
Well, I bought myself another top back in March 'cause I thought it was in better shape than the three I already had. Turns out, not so much...... 20220318_113115.jpg 20220318_113105.jpg
Howard2x4x4
Howard2x4x4
I removed the hatch and cut off the window sides where there was just thin sheet metal to contend with. Then, with a drill bit and a chisel and a pliers began removing the attaching pieces and parts that were spot-welded to the top.
Turns out, it was plenty rusty and corroded. Hmm, now what.....
Howard2x4x4
Howard2x4x4
i guess this is an inside joke and i'm on the outside. I dont get it:cautious:
Hmm, not sure just what is puzzling you, Shimmy. I hate to see a guy like you chagrined though. Tag along for a few more laps and maybe then maybe you'll see which way the wind is blowin'.
Howard2x4x4
Howard2x4x4
Once the spot-welded pieces and parts were mostly exposed, I took a wire wheel on a 4" grinder and cleaned it up as best I could. 20220722_112924.jpg
Then I sprayed some Rustoleum rust reformer in spots and used some KBS three part rust treatment in other spots. 20220721_101325.jpg
20220722_122255.jpg Next, I added some self-adhesive mesh to the entire inside perimeter of the top at gutter level.
Howard2x4x4
Howard2x4x4
And then applied two coats of resin to the meshed inside gutter area. 20220723_144921.jpg
Yeller
Rogers County Oklahoma
I’m with boncken. Had this in mind too.
Good luck with the tops Howard
Shimmy
1977 Bronco
Maple Valley
not sure where my mind was. hahaha! carry on sir! hope it all works out!
Howard2x4x4
Howard2x4x4
I believe there's room for all of it Yeller. After seeing what Ken and you chipped in, I'm thinkin' the upside-downer pics fit right in - kinda like two birds ith one stone.
Howard2x4x4
Howard2x4x4
Shimmy, I hope it all works out, too! Truth be told, I'm not always sure where I'm goin' 'till I get there.
Howard2x4x4
Howard2x4x4
I cut back the corroded flanges as much as I dared, hopefully leaving enough 'meat' to weld on the replacement metal stiffners that are being fabricated. Brushed on a coat of white epoxy to hopefully encapsulate any rust that hadn't seen the light and been 'reformed' by the Rustoleum and KBS. 20220723_144910.jpg 20220723_151430.jpg
Howard2x4x4
Howard2x4x4
Emergency Weather Newsflash!! Last night, a ginormous thunder and lightning and rain downpour passed through the area, enough rain that I thought about building an ark. Thunder woke me at 2:30, and I realized that my hoped-for safari top was outside the barn, upside-down, serving as a rain gauge! Not wanting the top to buckle, I threw on some p-jammies and got in the truck and drove to the barn, 10 miles +/- away in Zeeland. Upon arrival, I find the top was water-tight and resembling a good-sized birdbath. I made some waves to lighten the load and then dropped one side to te ground, draining most of the water and avoiding flood damage.
20220724_032348.jpg 20220724_032631.jpg Howard in beatiful and interesting West Michigan
bronkenn
Bronco Guy
Southeast Ohio
Like the old Wheel Horse Howard. I bought a new one around 84 and that thing is still being passed around the family somewhere and still running. Oh, and nice job on the roof. Should be good and solid.
Howard2x4x4
Howard2x4x4
Big double yuppers on the Wheel Horse, Ken. I've had a few of them through the years and it seems you just can't kill them. Along ways to go yet on the top. I'm hoping the cancer will all be properly encapsulated. I'm having stiffners fabricated, and then I'll have to think about side-to-side re-inforcement.
Howard2x4x4
Howard2x4x4
Not sure how I get myself into this kinda thing fairly often, but most of the time I also get myself out. Decided to make the work station portable.
Howard2x4x4
Howard2x4x4
Does anyone know how straight the drip edge should be along all four sides and the x and y axis (horizontal and vertical)?
20220724_135526.jpg 20220724_135446.jpg 20220724_135539.jpg 20220724_135550.jpg
