So I’m using the 77 power steering box inverted y tie rod and draglink and trac bar.
Ok so that's a whole different ball of wax!
Since you're keeping with the Y-linkage it's a good thing you're planning to fab up your own trackbar drop bracket.
You'll use a dropped pitman arm for a '76/'77 Bronco, but then you'll have to size your bracket to drop the trackbar to just the right height to keep it parallel to the long tie-rod/draglink.
Since you have a '77 already, just match up what it had and you'll be fine.
If it's already apart and you didn't document it, check out some of the other member's '76's and '77's to get just the right angle on the two bars.
Remember too, the taller the lift and the bigger the tires and the wider the wheels (or those with less backspacing) the more pressure is put on the long side rod and when used hard this is what bends first.
If you're just going to be on the street and only using moderate sized wheels and tires, you might be fine. But if going off-road and playing hard with larger tires, your steering linkage is the weak link.
I’m also using the k bar s lift I had on the 77. I didn’t have either a riser or a drop bracket on my 77 but I would like to run one or the other on this 66 to see if it will drive any better than the 77 did.
It would have to I would hope. The closer you keep things to the way that the factory had them, the better off you are usually.
But again, since you're basically creating your own Franken-Bronco here, you are going to have to think way ahead of yourself and figure out what is important and what will work together best.
