I have an automatic, but I'm sure I could find a 3 speed bellhousing. What about a C6 that's bolted to a 400, can you change the bellhousing on that as well so it would work with a 351 / 302?
The 400 has a big block bolt pattern.
The C 6 is a one peice case.
You need a small block c6 to put behind the W motor
The 435 will work with a standard 3 speed bellhousing
The 400 will fit in the EB
The W is a better fit.
Good, that is what you need. Does not need to be a Bronco 3 speed bellhousing, truck 4 speeds work as well. As long as they came off 300 straight 6, 302 or 351W.
To change the bellhousing on a C6, you replace the whole transmission case. It is cast as one part. At that point it is usually just easier to replace the whole transmission.
