TheFlyingFist
Hey Bronco Fam,
There were a couple things I did to do this and I need your help narrowing down before I pull things apart.
When taking her out for a test drive, reverse and 1st works just fine. However, shifting into 2nd gear grinds and wont engage. I was successful 1-time shifting it into 2nd gear at a higher speed, but would grind again after trying several times.
Question? Should I re-adjust the clutch rod to be longer or is it a linkage problem?
Note: When car is off, I can shift the stick into Reverse through 3rd w/o pressing down on the clutch. Is that normal?
Appreciate all the help. I've learned a great deal through Classic Broncos. I hope to contribute soon.
Thanks,
Neil
- Just installed 3-Speed Hurst shifter. Made sure everything was aligned to neutral when installing. Seems to shift through all gears when car is off.
- Adjusted clutch rod. At first I shortened it to allow for more slack but didn't like the feel, so I lengthened the rod again.
Thanks,
Neil
