jonmelton
- May 24, 2012
- 270
Hey guys, I'm having trouble getting my bronco started and wonder if anyone has any ideas. Here is A LOT of back story, but I'm a detailed guy.
I have a 1975 with a stock 302. I haven't been able to get it to pass emissions and have been slowly doing work to get it to pass. When I bought it a year ago, it ran fine. Since I bought it I haven't done anything major to the engine, I've replaced the distributor cap, 2150 Autolite carb, and spark plug wires. But, a few months ago I pulled it in the garage to work on the heater and change the C-bushings. The hoses to the heater had been disconnected by the PO, so I flushed the radiator, put on a new pair of hoses to the heater, and rebuilt the heater box under the dash. I don't think any of this has anything to do with it not starting, but now you know.
After I finished the bushing install, and the heater rebuild I started it back up. It was running really rough, but I just thought it was due to the freezing cold weather and that it had been sitting for a couple months. I drove it around a bit and it never really cleared up, but from the bushing install my alignment was way off and every time I hit the breaks it pulled scary hard to the right, so I didn't drive it over 30 mph. On my second trip out it died at a stop light. I kept trying to restart it, and at one point it restarted but it was acting like I was flooring it so I killed it. After that it wouldn't start again.
I got it back to my house and started troubleshooting. I would put gas in the carb and it would turn over and run really rough for a few seconds then die. I made sure I had gas, checked my fuel lines, checked my fuel switch, and just figured it was my fuel pump. So today I replaced my manual fuel pump, and I still can't get it to start. Still when I put fuel in the carb, it turns over and runs really rough then dies.
Any ideas?
Any ideas?
