with vacum advance you still have mechanical, vacum is strictly low load advance, give it gas it shuts off, mines plugged off and i run more initial, but if your looking for freeway milleage you should run one.i have a pretty big cam 270duration .500 lift, and i have real good vacum above 1500 under light load so it would still work great on the freeway, i know this because my vacum wipers still work the same with the built motor above 1500.
