I didn't find anything in the archives on this part, but I could be blind. I don't have the typical problem with the bottom pivot. Instead, the top (at mid window leading edge) bracket is broken.
I have late model EB door frames (not bolt-on window frames). Of the 2-part bracket that has a riveted pivot point. the door mounted piece (not the window frame mounted piece), is broken. It's still solidly attached to the door frame. The circular part that holds the pivot rivet is broken.
How is this bracket attached to the door? It seems to be inside the glass channel and probably tack welded. How on earth do I get this thing loose without removing the weather strip/gasket and griding it off? I don't even knw if a drill bit will fit in there, and I don't want to screw up the door frame from the outside.
If I open my driver's side vent window it will fall out because there is no top pivot rivet and the door frame mounted part of the bracket is broken so it won't hold a new rivet.
