PsYcHoBrOnCo said:
if i lift it first and say i put 35's on it what is going to break?
When my 30 died, this is what went.
Spider gears had a couple teeth missing. One side gear was completely stripped, the other had 3½ teeth left. Pinion gear looked perfect. Ring gear had 40 broken or cracked teeth (one still looked good). Axle shaft seal leaked. Axles were still good. U-joints were sloppy but intact. Upper kingpin lost its guts and the tire was leaning over.
Even with all this damage it still worked. I pulled it apart laughing my ass off at everything that was wrong. I had just returned from the cinders and I know the 4WD was working, I have seen the video of it on Arizona Classic Bronco vides volume #3. Even have a cool shot of spraying the camera with cinders.
I knew something was wrong afterwards when I was trying to get to a lunch spot and had a hard time going up a hill. My brother asked why the front tire on his side wasn’t spinning. I looked and the drivers side was spinning at the same speed as the rears. I parked it. Did the group picture. Got stuck in the bottom of the bowl, put it in 4 WD (or maybe it was 3WD, who knows) and drove out. Put her back in 2WD, unlocked the hubs, went home and found the chunks.
That was the death of my D30. The D44 has exploded one U-joint (same size as the D30 joints) that led to the updating with chevy axles with 297 U-joints.
At least I got to pull the disk brakes off the D30 and move them over to the new D44 (chevy conversion)
All that was with 33's
