I recently bought a 1974 Bronco with a 302, power steering and A/C. Since purchase I had the A/C fixed and have had alternator problems. I burned through two alternators and finally decided to go with a higher amp alternator to fix the problem.
Once the higher amp alternator was installed I drove it about 20 miles and the belt got twisted and broke. In looking at the pulley alignment it appears the water pump pulley is out of alignment and is too far forward. I am not sure why I did not have this problem before but the new alternator and other pulleys appear aligned with the exception of the water pump. Maybe once the belt was changed it was less forgiving?
With all that said my question is regarding the water pump pulley. Does anyone know what pulley I could use that will bring the water pump pulley back toward the firewall about 1/2 inch?
I tried my best to capture the misalignment in a pic.
Thanks!
Thanks!
