Usless od IMO
what if I was to go to 389s split the difference for now 3 speed and 33s and still be good for NV3550 later ?
my first 1500 + mile trip will probable be before i do the 5 speed swap
Here is a handy tool to play with if you haven't already.
http://web.archive.org/web/20050204061805/home.comcast.net/~jcmiley/bronco+gears.html
If you are that set on the NV3550 then your long term gearing plan should be for something like 4.56s. Even with 4.56 and 33s and the 3550 you'd only pul 2500 rpm at 69mph. A 302 needs that or more to be in the meat of the torque band and push that brick of a Bronco through the air efficiently.
It's the reason so many casual wheelers probably love the NP435. With its low 1st you don't need to change your gearing to get a good crawling ratio and upsizing tires with stock gears gives you an overdrive effect in 4th on the hwy.
Plus they are cheap
http://albuquerque.craigslist.org/pts/2547860727.html
Not mine BTW.
Re-gearing is a lot of money especially if you start adding new diffs to get lockers and such.
If you aren't cutting the front maybe 31s would be better anyway. No matter what I'd skip the gearing for now. Drive it a little while to get a better sense of what you really want and that you are happy with what else comes with larger tires as mention in the post above. So what if the bigger tires are harder on your clutch you need motivation for your tranny swap anyway, right?
It's all about how much $$ you want to spend.
