what is best air cleaner for Holley EFI
Vshofel
Newbie
hi i am new to this chat as a new bronco owner - i have a 1970 automatic - 302 with a recently installed EFI Sniper - Need to upgrade air cleaner and not sure if the old snorkel system is the way to go or it doesn't make sense for a 302 with an EFI?
The best air cleaner is probably the stock one that has the flex duct to the grill. Actual factory cold air intake.
Big issue with early Broncos is hood clearance. So many aftermarket air cleaners run into the hood. Drop base runs into the distributor. And pulling hot underhood air.
56f100bbw
Tucson / lakeside AZ
He is right on
Vshofel
Vshofel
Newbie
thank you bowsher, where do you recommend to get the full unit? and approx cost?
Check with the Bronco venders you like. They are all used parts. Don't know who has what for inventory these days.
blubuckaroo
Grease Monkey
Ridgefield WA
I like the big Edelbrock triangle air cleaner. If you flip it around backwards, it clears a Duraspark cap, the throttle linkage, and the crazy Edelbrock carb fuel inlet.
It fits in the Bronco, and looks cool too.
If that is the one I am thinking of, wire mesh over coarse black foam, it does nearly no filtering. Keeps boulders and small children out. but lets fine grit go right through. As far as filtering goes, probably the worst filter possible. A backfire also sets the foam on fire. But they are good for hood clearance. And very inexpensive.
Vshofel
Vshofel
Newbie
Trying to find one that is available, but not all parts are there or in stock and no update when it will be available - so i have to wait - i called summit racing and they said this item below will fit and it will be cold air intake - is anyone familiar with it? they make a low profile one as well SPE-752
Spectre Performance SPE-751 - Spectre Performance Musclecar Cold Air Intakes -​
blubuckaroo
Grease Monkey
Ridgefield WA
NOOO!
Like I said... the big triangle.
If you put it on backward, it clears the big Duraspark cap, the throttle linkage, and the Edelbrock intake fitting.
https://www.edelbrock.com/pro-flo-chrome-triangular-air-cleaner-with-2-5-cotton-element-1222.html
