Which Flares . . .
Scoop
Have Bronco, Will Travel
Cuchara, CO
. . . and why?
I got a "gift certificate" for Christmas - good for the purchase of a set of flares of my choice! Now the dilema - which ones? I want to go with wide stretched openings and somewhere about an inch or less down from the body line. I think the only choices are WH Gorilla Warflares, Silverbacks, or Duff's UFOs. I don't want/need the 4-inch wide Silverbacks so that leaves the Gorillas or UFOs. First, any others I need to consider and second, what are the pro and cons of each? How are they holding up to trail abuse?
I like the flexibility of the UFOs but not sure if I like the high gloss finish on the UFOs as much as I like the matte finish on the Gorillas.
Thanks.
73stallion
Eugene, OR
i won't be running duff's flares again, their finish doesn't stay on. it's getting worse, that was a few months ago. so don't worry, the high gloss won't last long!
blubuckaroo
Grease Monkey
Ridgefield WA
If you have previously had flares installed the openings may bee too large for the new flares. I bought a set from Duff thirty years ago and had trouble finding a set that would cover that cut-out.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The gorilla flares are bigger than anything I have seen. Certainly bigger than flares that were bought in the 70s.
chris
No more Rock Crawler
WH here also, they are the only things on the truck not giving me trouble at the moment. %)
green77bronco
SAn Antonio,TX
I just replaced my fiberglass flares, with a set of Gorilla flares. I mounted them a little higher with a bigger opening. Came out good. Very happy with them.
Pearlcoat
Gary - you mounted the gorilla flares on my trail rig, want to take a second look at them? No issues with them even as Roger (or was that Caine?) scraped a tree at Blue Rocks and tore the mirror off.
nj_thusar
Asbury Park, NJ
WH Gorillas...
But I defiantly recommend using a stainless nut and bolt combo. Picked up a black set of hex heads and lock nuts... looks sharp and has already come in handy when taking them off.
Scoop
Scoop
Cuchara, CO
Thanks for all the replies. I was expecting a bit more enthusiasm for the Duff's. Like I said, I like their flexibility but I havn't had much experience with them.
Ben, is the gloss black finish on your's painted on? I thought they were color-moulded?? From the pic it looks like gloss black paint over an off-white material.
Good thought on seeing if I can get some blems - this is for my trail rig and I'll be trimming the bottoms some anyway.
Airborne69
Moorpark, CA
i have the duff's flares in white and the white is just painted on. and they aren't any bigger than fiberglass ones would be.
4lofun
i used the WH , i recomend that you use nuts and bolts. i used size#10. allen headed bolts, nylock nuts, and washers with rubber bonded on. i figured once painted the tub. i wont be drilling and creating future rust issues.
Rockmnky
Newbie
Warflares look the best!
]I just added warflares to mine ,at a inch from the body line. These also are blems but I can't see anything wrong with them!
gotdads68
I think mine are the old bushwackers and they have faded over the years to grey. On a side note, I mounted mine with plastic rivets available at auto paint stores, they've held up for over ten years and aren't as obvious as the silver rivets are.
