BajaFresh75
- Jan 26, 2005
- 5,486
I have a 74 that is running extremely hot. The gauge is reading over 230 degrees. I have a laser thermometer and all the readings on the water neck, hoses, radiator, intake, sending unit all read 135-175 degrees. Here's a list of what I've done. Some of this I was doing any way.
1. new 4 core radiator
2. new heater control valve
3. new heater core and blower motor
4. new sending unit
5. hooked up another temp gauge from another EB cluster (same reading 230 degrees).
Any ideas? The water pump is not that old, and FYI I'm not sure if it has a thermostat, I'm assuming it does. The Bronco runs and drives fine and doesn't overheat, but I hate looking at that gauge and seeing 230 degrees!!! I thought about running a new wire from the gauge to the sending unit. Any ideas welcome!!!
4. new sending unit
