winch bumper progress
malcolmzilla
Calgary, AB, Canada
A few pics, kinda makin it up as I go...
What is everyone doing to affix them to the frame? I was thinking about filling the factory holes and sleeving the inserts and bolting all the way thru, so I get both shear and compression of the frame on the inserts...
SC74
Very nice fab work. I also like the idea of sleeving the mounts. I would beef up the tab between the hole and end of frame rail too - seen those rip out before.
malcolmzilla
malcolmzilla
Calgary, AB, Canada
Thanks, getting used to using the torch.
For affixing it, I'm thinking of using 7/16" bolts all the way through, both horizontally, drill through below body mount and filling the factory bumper tabs and drilling another bolt vertically thru there but a bit farther back...
Mine has been front ended so I had to heat and beat and weld the frame horns and slots back into shape, so drilling a bit farther back out of the HAZ is advisable I think...
brian72
Early Bronco Student
oh good - more photos, cause I thought it was going to be one small bumper...:)
hammer
Thanks for the pics. I'm going to have to tackle this as well. Really helps wrap my head around it.
MustangHowie
Shelley, ID
It is looking good. I can't wait to see it complete, and on the truck.
I plan on taking mine to work this spring and making one for mine.
Devin
Bronco Kineticist
That is looking really good. Thanks for posting the progress.
malcolmzilla
malcolmzilla
Calgary, AB, Canada
2x4 .120 wall inserts, same wall as frame. Takes a bit of hammering but goes in and out.
Bumper and winch plate is .188, cut out of 2x8.
Progress so far today. Let me know which side line you like: 18", 19" or 20". ;D
dieselracer
Citrus Heights, CA
Yeah, 18" with a piece of 1/4" plate that caps off the bumper and protects the fender back to the edge of the flare. That looks awesome. Eventually I will get around to building one. I have been contemplating a pre-runner style with two tubes that will go around the top front corners of the fenders/grill and tying them into the main hoop too.
drscotch
Edmonton, Alberta
I'd go 18, I'd hate to run my knee or thigh into 20 walking around the front. ;D
Do you know if that 2x4 0.120 fits the rear frame as well?
malcolmzilla
malcolmzilla
Calgary, AB, Canada
Split the difference @ 18.5"? :D
I will post the rear inserts when I get back to working on the rear. Yes they fit, with a bit of notching for the bodymounts.
Just out and picked up some towhooks, had a factory forged set off a K3500 but they are too big and ugly. They will be hidden underneath out of sight.
Plan to add a strongback to rear of the winch plate, this will also give me a spot to pound the sledge on to remove it - I am mushrooming the rear lip right now - the last 1" takes persuasion.
Also got the back horizontal bolt holes drilled using the factory one on the inside as a pilot, had to trim the drivers body mount back a bit, should take 1/2" bolts.
I am also debating doing a hidden mount for the front vertical bolts...
Also, I dont think the winch will come out without removing the bumper, ~1/2" to grille... Hopefully slow a thief down. And a tackweld on the footbolts. ;)
Debatin' hilift mounts too. Can do 'em later, kinda diggin the flush look.
I'll snap some more pics as I go.
DonsBolt
Chestnut Hill, Mass
Looks like your doing a awesome job
I say 18 at the most, but I like things Tight, hehe
Something like I did when I modified my B built Bumper ends
malcolmzilla
malcolmzilla
Calgary, AB, Canada
More pics, with winch in, the angle iron represents the grille location when mounted. Big assed tow hooks: free, you pay shipping! ;D
