meanjean73
I have everything installed and the shifter/gears aren't lining up. By that, when the shifter is in neutral I am actually in drive. When I put the shifter into 2nd gear, the transmission is actually in 1st gear. The transmission goes into reverse before the shifter actually gets to reverse? I can't get the shifter to physically go into first gear.
See what I am getting at, everything is off?
I am verifying the actual gear by the read out of the Quickshift 4 controller and comparing it to the shifters physical location in the gates.
So, are there adjustments somewhere on the shifter? The instructions aren't very specific about fine tuning.
Also, For those who have this setup, any pictures of your cable mounting bracket on the transmission would be great. I had to modify the Winters bracket to get clearance on the transfer case and front driveshaft. Maybe my bracket modifications threw everything out of alignment?
