Quote:Originally Posted by DirtDonk View Post
Yes. With the Black w/green wire handling the MSD box, it's going to be on with the key in ACC as well as ON. Not really a good thing.
Change the ignition back to one of the on in RUN only and you should be good.
If I keep the Green/Red (12v in Run) wire running from the ignition to the alternator and splice the MSD power wire into it, will that be better?.
That should work. Shame to have to splice of course, but it should be fine. With all that available space in the fuse box, it would be nice to run them both from their own circuits on the "keyed" side, rather than straight from the switch.
No reason to change what you're working with though. Just sayin'
Which part number panel? As Eric mentioned, it might not be compatible unless you break the buss-bar into two discrete sections you can then control by the different wires.
If that's possible to do to this box.
http://www.painlesswiring.com/Manuals/30004.pdf
10 constant and 10 switched.
Perfect. Just like the one I was looking at earlier. Nice box.
No problem there in theory, but you really don't want to be running all that power through the switch. I could be wrong, and someone will correct me if so, but I don't think the stock ignition switch was designed to handle 60 amps of current through it.
Maybe fuse it for 30, and see how it goes?
Correct me if I’m wrong, but isn’t the stock ignition wired the same way? Unless I’m looking at it wrong….highly possible, all the 3g wiring diagrams I have found show the Black/Yellow (Constant 12v) wire running from the B+ side of the solenoid to the ignition with a fuse between..
Not quite. In the stock situation, only those few items that have are controlled by the switch, actually get power through the switch. The other items, including some of the heaviest loads, have their own connections separate from the switch.
Things like ALL the lights, get tapped directly into the Black w/yellow wire. Maybe that's the extent of it, but even if so, then that's quite a bit that does not go through the switch. Headlights, instrument/convenience lights, tail lights, brake lights, hazards, signals and running lights, all get power from the headlight switch, which is powered directly by the battery.
And speaking of direct-from-battery loads... Are the large Red and Black wires from your MSD box hooked directly to the battery somehow?
Only the small wires get switched power. So, if you have your lights, MSD main power, and whatever else does not need a key, hooked to that side of the box that's not running off of the ignition switch, you should be good to go.
For a load, accessories like radio, heater, ignition, starter relay, probably only use a total of maybe 30 amps when they're all on. Hence the lower rating on the fuse and the need for not overloading the stock switch.
I'll bring up the relays again later.
No prob. if you can separate the halves of the box as mentioned above, and run the ignition off of something other than the Black w/green circuit.
See above. Not sure if that is possible.
There might be an overall solution coming. See more comments about relays below.
Ok for the alt and choke, but put the ignition box on it too, and you should be good. Or better yet, get cleaner power to the ignition by putting a relay in the line before the MSD box.
See above. I think I have it wired this way now. Not sure how to wire relays, but if they are necessary, I will figure it out..
That's the one you want to be powering half of your fuse panel. But since it's so small, and really doesn't have the capacity to run a whole slew of on-demand items with the key (in case you're thinking about adding accessories that is) maybe run it to a relay first, then from the relay power the fuse panel from the battery. Basically getting full power with the key, without running all the power through the ignition switch.
One of these days I might be able to understand what you just said.
Hah! Yeah, I know. I talk too much, but relays are a strange subject until the light comes on in the brain in an "Ah Ha!!!!" moment.
I'm going to start another post below with some suggestions about using a relay or two, and how to wire them up.
I really appreciate the help with this. Until I get everything figured out, I will not be starting the rewire process. I hope to be driving this thing before the summer is over, but at this point I'm not sure if that will happen.
I was going to buy a complete harness, but didn't want to hack up a new harness for the 3g and MSD installs..
No worries. You might consider doing the new harness at the same time, but you're already half way there with a new fuse box, and any pre-made harness is going to have it's own fuse box that would just be duplicating what you're doing now.
You've got a great setup started, and have already put some money into it, but it might just still be worth sitting back and looking at what you want to do overall. That way you can decide now whether you're going to stay with all the old wires, or start fresh with all new.
If all new, stop now before you pull any more hair out and get a harness.
If not, and you think your stock wires are still in serviceable shape, and you're not going to do a whole harness for a few years, then keep on truckin' in the direction you're taking now.
